Spindle control help please
After much tinkering, I decided that the problem with my micromill 2000CE was the Denstep board, so I am in the process of removing it and allowing a computer running LinuxCNC to control directly.
I have a 96 way connector and a breakout board which I am rigging up in a similar way to what Jay did here
https://www.summet.com/blog/2016/01/16/ ... s-control/
My issue is with the spindle control board. This looks very different on my machine:-
https://goo.gl/photos/aQ8RrmuRBLxwCRDT7
https://goo.gl/photos/gKEDKHotAwSUqqNL9
So I am wondering what is my best bet for controlling it.
My breakoutboard is this one:-
https://www.omc-stepperonline.com/downlo ... Manual.pdf
Which has a 0-10v output and wants a 12-24v input
Can I take a feed from the Siemens box's 24v output for this (down the bottom) and then feed it into the board somewhere to control the speed?
Is it possible to pick up these connections from the 96 pin connector on the main board for neatness?
If it is going to be a big problem to get speed control then I am pretty happy with an on-off solution at full whack.
Many thanks for any advice on this.
George
Re: Spindle control help please
Not sure on the connection to other control gear but (I may be wrong on this) I'm sure the speed controller has a 10v, 0V and an input. You could wire the spindle override from the front panel with one side at 10v other side at 0v and wiper on input. to give you an element of control.
I think it is the bottom 3 connection on the left in the pic of the speed controller, you have what looks like a brown and a blue in the input and 0v.
I'm also sure I read somewhere about the 10v on the speed control needing isolating as its somehow linked to 220v. I can't remember exactly but someone was trying to do something similar (possibly in the link you posted).
Might be some more info on the speed controller if its the same as this...
viewtopic.php?f=46&t=4778
TDIPower wrote:Not sure on the connection to other control gear but (I may be wrong on this) I'm sure the speed controller has a 10v, 0V and an input. You could wire the spindle override from the front panel with one side at 10v other side at 0v and wiper on input. to give you an element of control.
Thanks for replying.
I think you are right about the bottom left connections. I put the Denstep board back on and tested here and saw 1.6 volts at a low spindle speed.
Unfortunately I think removing the denstep board has left the main board with no battery to retain the firmware and spindle speed control now no longer works (ie. stuck at very low speed).
I then tried removing the denstep board again and putting a 4volt supply onto these two but nothing happens, which I assume is because the SGR (Spindle go relay) isn't triggered?
Anyone have any ideas on the best way to trigger (or bypass) the go relay?
George
Have you found the wiring diagrams I'm sure they are on here somewhere?
TDIPower wrote:Have you found the wiring diagrams I'm sure they are on here somewhere?
Yes. They are in the sticky thread above.
viewtopic.php?f=36&t=2929
Relevant one for my machine appears to be the Micromill-denstep-electrical-June2000.pdf
6th one down in first post.
Speed control boards on pages 5,6 and 7 all have Red Blue wires from Denstep board at 0-10v
Then Spindle Go Relay SGR at pins 4 and 5 on that board coming from 84 and 85 from pins 14 and 11 on the SGR itself
Other side of SGR is 82 and 83 with a diode across the top like the later revisions.
Page 12 shows the 83 cable going to pin 0 of the TB3 outputs on the main board then the otherside going through the guard contact to the 24volt side of the siemens transformer 24v through wire 61.... I think...
Does this mean that if I wire the top side of the SGR to my 24volt switched output of my breakout board it will trigger?
Sorry if this seems obvious, I'm well out of my depth here.
Be very careful with the speed control. The Denford spindle drive requires a DC ISOLATED 0-10v input to control it's speed, this must not be connected to ground in any way. DIYCNC make a board that can control the spindle board from a computer, i'll try to find it and add a link.
I knew there was something I had read on here about having to isolate the 0-10v. Someone had been adding another control board but was having issues with this part. Have a good search/read, it might not have been on a micromill but I'm sure Denford used the same unit in a lot of machines.
angel-tech wrote:Be very careful with the speed control. The Denford spindle drive requires a DC ISOLATED 0-10v input to control it's speed, this must not be connected to ground in any way. DIYCNC make a board that can control the spindle board from a computer, i'll try to find it and add a link.
Surely in the original setup this input was ultimately coming from the Siemens transformer anyway? So if that's where I pull my supply from too it should be fine?
Am I right in my supposition that connecting the 24v accross the top of the SGR is going to turn it on? Or will this damage something?
George
Mr Magoo, Martin, Steve
