Hi!, how can I get this drivers?
As the title says, how can I get this drivers? the monitor in the machine doesn't work so I need to use the PC.
Screenshots:
Machine: https://prntscr.com/d2sw6u
Model: https://prntscr.com/d2swmp
Error: https://prntscr.com/d2sx5b
To use the machine (before the error) we use this program and it worked, but now I don't know how to get that drivers
https://website.denford.ltd.uk/support/9 ... s-software (Mirac)
The Drivers inside of DRIVERS and DRIVERS2 in the denford page doesn't work, so I hope find a solution :D
Thank you for your attention! (and sorry for my bad english)
Re: Hi!, how can I get this drivers?
Have you checked the control card in the electrical cabinet. I presume you will have a GSM LCB3 board fitted with it being a 1991 build. Just check it is powered up. In order to connect you need to have the correct Mirac.go file for the machine & connected via a RS 232 cable to the control card. Has any of this been changed?
