Denford Easiturn Parameters
alanm157
Post by alanm157 » Mon 09 May , 2016 16:36 pm
Hi there,
We recently moved our Denford Easiturn to another site and havent managed to install it since.
The menu has reverted to spanish and when you pick any of the options the power goes off.
Could anyone help us get the parameters as we don't seem to have a copy of them.
Machines details are:- Denford Easiturn
Serial No. ET06029A
Alan
Re: Denford Easiturn Parameters
Post by Martin » Tue 10 May , 2016 8:37 am
Hi Alan,
What control & model is fitted? I presume it's a Heidenhein.
alanm157
Post by alanm157 » Tue 10 May , 2016 11:53 am
Hi Martin,
It has Fagor 8020 controls
Post by Martin » Tue 10 May , 2016 13:44 pm
This is all I could find.
DOC100516.pdf
(780.63 KiB) Downloaded 1235 times
alanm157
Post by alanm157 » Wed 11 May , 2016 11:11 am
That's great Martin, Hopefully the engineer has enough info. to get it up and running now.
thanks
Alan
alanm157
Post by alanm157 » Fri 13 May , 2016 11:00 am
Hi Martin, do you know how to go about entering the parameters?
All we have is the "modos operacion" menu with nine options.
Also is there an internal power supply/memory that needs replaced?
the machine was disconnected for 5 months
Alan
Post by Martin » Fri 13 May , 2016 12:21 pm
Hi Alan,
I have attached some Fagor manuals which may help.
I can't remember how they were but hopefully the manuals will help you.
Fagor 8020T programming manual.pdf
(8.22 MiB) Downloaded 1617 times
Fagor 8020T Programming Manual Addendum.pdf
(782.44 KiB) Downloaded 1394 times
Fagor 8020T Operating manual.pdf
(3.47 MiB) Downloaded 1627 times
Fagor 8020T Operating Manual Addendum.pdf
(459.86 KiB) Downloaded 1379 times
alanm157
Post by alanm157 » Mon 13 Jun , 2016 14:33 pm
Hi Martin,
We have managed to input the 5 parameters MP 21,22,23,61,and 63 from the parameter list.
However the engineer says we need to enter 148 parameters as the default ones that appear dont work.
error codes 108,194,099 and 110 appear when trying to run on current parameters.
thanks
alan
Post by Martin » Mon 13 Jun , 2016 14:48 pm
Hi Alan,
I can't find anything more on Parameters.
alanm157
Post by alanm157 » Mon 20 Jun , 2016 16:17 pm
Thanks Martin
ParticleFire
Post by ParticleFire » Thu 11 Apr , 2024 4:50 am
Hi!. Someone have the installation and startup manual of Fagor 8020T? I lost the parameters...
Thanks!
