just picked u an old Micromill from an Auction. Unfortunately no software, manual or cable. The Mill is dated 1996, so I guess it might still run on the dos software.
The Eprom has the following number : 2.0.B/10/S/B19-JD5.
Does somebody know, if this indeed runs on dos, or what would I need. I also noticed, that the card itself has a smaller serial port cable, which is soldered on the other end to to the old style large serial cable. Can I just use a regular serial cable for this ? if not, what cable?
thanks
Stefan
The EPROM is for the Newer VR Milling software so will not run from the DOS Software.
The External serial cable is a standard 9 - 25 serial cable.
You could make up your own and connect direct to the controller card
See:
viewtopic.php?f=54&t=2351&p=15044&hilit ... ble#p15044
See:
