Triac Spindle Speed Upgrade
Post by cdmodelz »
Hi All.
Is it possible to upgrade the spindle speed on the Triac to (for example 8000rpm)?
I have seen a video on YouTube where a Triac Fanuc was upgraded to 10000rpm by fitting a Chinese 2.2Kw spindle motor and a radiator/pump to cool it.
Would the spindle bearings be capable of this speed?
Hardware/Software: .....
4 Quatros
3 Oracs
2 Easiturn atc
12 station lathe atc
Mach 3
Re: Triac Spindle Speed Upgrade
Post by angel-tech »
Hi Brian. With a 3:1 reduction you can get 8000 rpm from the chinese spindle and the bearings are close to the max op speed. I would replace the bearings with better ones to be on the safe side.
Post by cdmodelz »
Is it a big job to replace the bearings?
I wouldn't mind getting a third Triac VMC to make several upgrades to.
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
fairly easy job, nothing about this end on the vmc.
Post by cdmodelz »
What would be best bearings to replace with (source).
Would be nice to upgrade to triple stack steppers to increase rapid feedrate.
Martin, Steve, Mr Magoo
