We have a Denford Vertical Router and are having issues with the connection breaking down between the machine and the laptop. Everything connects fine and the cut begins fine, but at some point it almost always cuts out showing 'Unrecognised error 1227'. It then shows 'Invalid data field length for transaction' if you try to click anywhere.
On the first cut of the day it tends to get a few minutes into the cut before cutting out. If we restart it, it then cuts out before the cut even begins on the next try.
Any ideas what this could be?
Jack
