Hardware/Software: Triac Vmc with 6 station ATC
Starmills with ATC
Starmills with ATC
Turns out I need a new stepper motor on my triac, when under any sort of load even light it's stalling.
I don't want to replace the drive card or stepper housing can anyone recommend a replacement?
I do have an urgent job but that's out the window now
Hardware/Software: .....
4 Quatros
3 Oracs
2 Easiturn atc
12 station lathe atc
Mach 3
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Hi Andy, is the fault more than just the drive pin.
Starmills with ATC
Starmills with ATC
Sadly it is yes.
With just a light bit of pressure on the cog it's stalling so it needs to be replaced
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
is it ok to call you
Starmills with ATC
Starmills with ATC
It's proving very hard to get a suitable replacement, current shaft is 9.5mm all New nema 34's are 12-13mm
Can anyone help, does anyone have a triac stepper spare?
Need one urgent
If I get a bigger shaft then the cogg/pulley won't fit
Need one urgent
Starmills with ATC
Starmills with ATC
As I don't know the spec of the current strippers in the triac at the moment it's very to buy a new one.
Anyone got any thoughts on if this is a suitable replacement
MY34HY0-5
https://astrosyn.com/section.php/55/1/my34hy_series_1_8
Measurement wise it looks the same as current
MY34HY0-5
Hardware/Software: Optimum D280x700 CNC lathe
HBM25 CNC mill
Denford Triac CNC mill
eShapeoko CNC router
Rostock MAX 3D printer
ShaperCube 3D printer
BobCAD-CAM V26
ViaCad Pro 8
OpenSCAD
HBM25 CNC mill
BobCAD-CAM V26
ViaCad Pro 8
OpenSCAD
Did you ever get this sorted out?
I'm in the process of converting a 1985 (green) triac to mach3 and my x-axis motor is bust.
gallenat0r
gallenat0r
Starmills with ATC
Starmills with ATC
yeah x motor replaced, I found a plate that did a pretty much identical stepper.
also replaced bearings on the x table
Hardware/Software: Denford Triac PNC3
FeatureCam - CADCAM
Delcam Powershape
FeatureCam - CADCAM
Delcam Powershape
Hi Andy, As quoted was this the correct motor replacement?andy_con wrote:As I don't know the spec of the current strippers in the triac at the moment it's very to buy a new one.
MY34HY0-5
Starmills with ATC
Starmills with ATC
