Starmill - ATC - Compressor
just looked in the starmill manual and it say if the air pressure drops before 90 B.P.I. the atc will stop working.
what is 90 bpi?
would this compressor run the atc?
https://www.ebay.co.uk/itm/241183-Silent ... 43be02c5d5
Re: Starmill - ATC - Compressor
I presume it should read psi?
90 psi = 6.21 Bar.
We used to set them to run between 80 to 100 psi so the compressor should be fine.
oh right I see thanks
