Manual control
I am looking help with wiring a ASHE FX1500 spindle controller, It controls a SEM 130v motor and I am trying to avoid changing it as there could be problems with mounting on mill etc.
I would have liked to control the motor via MACH3 but running it manually would do for now.
I believe all I have to do is connect a 30K potentiometer across pins 1,2 & 3. I would like to know
if this is right. Pin 3 has 12v on it,also terminals F+ & F- have 220v across them what is this used for?
thanks Jim
Re: Manual control
F+ and F- will be the field output (for a motor with Field windings that need energising, rather than permanent(fixed) magnet which I believe your SEM motor will be)
Have you got an instruction book for the ASHE drive ? I'm not familiar with it so can't comment on the pot. connections
Re: Manual control
no don't have any info, I was looking at other posts with the same problem,( Different control boards) where it was suggested to put a pot with 5v on it in place of control signal
Re: Manual control
There are normally 3 terminals for a potentiometer.
1- supply - to one end of pot
2- command - to centre of pot
3- common/ground/0v - to other side of pot
If you had a two wire analogue output you would only need to connect to pins 2 and 3 in this example
Re: Manual control
There are 3 terminals, I was going to connect the pot across them, there is 12v on one of them so wont need an external supply, have to source a pot yet
