QuickTURN2D v1.18 released 21st Jan 2013
Post by Denford Admin » Thu 18 Oct , 2012 9:40 am
//v1.18 - 11th Jan 2013 - added post option to output some text before every Tool Call
//v1.18 - 11th Jan 2013 - Changes to drilling cycle:
// drill depth adds on the length of the drill's taper so enough material is cleared before boring.
// to turn this off you could always change drill tip angle to 180 degrees
// After each peck the drill is brought fully out to clear swarf off flutes
// Drill is rapided back to 1mm in front of last depth drilled (if Options > Machine Options > "Cycle clearance in Z" is >0 then that value is used, normally 0.8mm)
//v1.18 - 21st Jan 2013 - Added Pecking option to drill and centre drill. So, drills could be made to not peck and centre drills could... if you wish to set it up like that.
Check here to download the latest version of all software:
