further problems
Alan W notts
Hardware/Software: just purchased novamill software none 2.95 on machine label
further problems
Post by Alan W notts » Sun 02 Jun , 2013 17:20 pm
Hi again...
ok I have got everything moving in jog all appears ok.
however when I try to run any of the progs supplied with the machine it is always coming up with machine axis exceeded or words to that effect.
I am wondering if the home position is correct for the machine it is as follows.
x all the way to the right
y all the way forward
z maximum height.
any help appreciated.
its a 97 machine no atc fitted
cheers.
Re: further problems
Post by Martin » Sun 02 Jun , 2013 18:41 pm
It sounds like you have not set any offsets.
Alan W notts
Post by Alan W notts » Sun 02 Jun , 2013 21:56 pm
looking at the manual that came with the machine it would appear the x axis is set all the way left for home.
I have had encouraging results by re setting the datum but looking at the manual if the x axis was altered all would be ok.
thanks for the reply I hope the help keeps coming.
Post by Martin » Mon 03 Jun , 2013 15:06 pm
If it homes then the direction must be correct.
Can you manually jog all 3 axis to the software limits?
Alan W notts
Post by Alan W notts » Mon 03 Jun , 2013 21:21 pm
manually I can put the machine where I want .
seems by setting the datum at x100 y-80 z-50 I can get programes to run
maybe I will have to off set the zero by using a datum point as such?
or programe from the existing datum ie in reverse which is a ball ache
cheers
Post by Denford Admin » Tue 04 Jun , 2013 9:05 am
Is the X axis the problem - it sounds like it might be counting the wrong way ?
If you move the tool to the left-hand side of the table the X should count negative (ie go down)
If you move the tool to the front of the table the Y should count negative (ie go down)
If you table is homing out to the right in X, then the X datum values will be positive so what you've said sounds right.
