FANUC CNC milling(soft homing issue)
Hi, we are working on a denford CNC milling machine and the problem is we are not able to soft home the machine in the desired co-ordinates... Need help regarding that. Thanks
Re: FANUC CNC milling(soft homing issue)
Which machine and software have you ?
Is the machine physically moving to the home switches and backing off slightly ?
Both vrmilling v2 and v5 have help files showing how to set the work offsets so that the machine datum is in the correct place.
If it's a true Fanuc control then power up with "P" & "Can" pressed.
