i can drip feed into my triac 1990 a prog that works fine but when i try to transfer the same prog into the control it puts in blank lines???? any help?? comms error??
Quite often the text of a CNC program has ascii characters 10 and 13 (carriage return CR and line feed LF) at the end of each line.
Depending on the control reading this in, it could be reading both as the end of line marker, hence you will see blank lines in between each one.
Try loading the program into a good text editor and have it re-save in another format - with only ASCII 13 (CR) at the end of the lines
- Admin on holiday
