Post Process to TNC 145 ?
Hello all
Just registered today having spoke to Martin Ironmonger, I have lots of questions but first can i post process to Heidenhan tnc 145 if i can what software can i use ?
regards and thanks in advance
Re: Post Process to TNC 145 ?
It depends on which CAD and CAM software you are going be using.
None of our CAD/CAM has a post processor setup for Heidenhain but I'm sure there will be lots of CAD CAM systems out there that will post to TNC145/155
We have Inventor, also autocad LT and techsoft 2d. will any of these do? is Inventor too recent ?
regards
All those are OK for creating 2D and 3D desins which can be used by CAM software.
You just need to find a 2D + 3D CAM system which will post process to either Heidenhain Dialogue or Heidenhain ISO G Codes (I think the TNC145 had the choice of both languages...Dialogue is the default Heidenhain programming system which made it easy for operators to program fancy stuff like bolt holes and pockets)
I'm sure any of the CAM systems available will have an Heidenhain post.
Our own CAM software will output plain g-code programs and could be configured to let the TNC145 recognise them in ISO mode. We just don't have the ability to test it out.
PS this manual for the TNC355 will be mostly relevant to the TNC145:
viewtopic.php?p=3945
Hi there
we have brought a design from inventor (saved as an STL file) into Quick Cam. There was a problem when recognising the size from inventor e.g 25mm cube on inventor showed up as 2.5mm cube in quick cam ? any thoughts or ideas ? Also it asks if the model is imperial when quite obviously it is not.
regards
Colin
STL files do not contain unit information so the software guesses the model units could be imperial when it sees a small model.
eg, the average model size for our machines is about 100mm square so if .STL comes in and is 4 units square then it prompts you with the question.
The best thing to do is export the STL in units of mm...there may be export options from the CAD software, or you may have to change the current drawing units and it will then use those when exporting the .STL file
