Can someone tell me which wires on my original orac stepper motors should be paired together for parallel bipolar operation, and which of these pairs is A+, A- etc?
I tried using the method outlined here (https://www.piclist.com/techref/io/stepp ... attery.htm) to identify them, but the trouble is I don't get the same pairings as were originally tied together on the plug at the end of the stepper cable (I made a note when I stripped it). Foolishly I connected the stepper using the pairings I'd identified to a picstep I'd built and promptly blew up one of the driver ICs (lmd18245 - expensive!).
So I want to make sure I've got everything right before I destroy anything else.
Any help is gratefully received!
Thanks,
Luke
There are 8 wires. The colours are
Red
Black
Orange
White/orange
White/red
Yellow
Black/grey
Yellow/white
And the original pairings were
Red & white/yellow
Yellow and white/red
Orange and black/grey
Black and white/orange
But I don't know what these pairings are (A+, B- etc), and I'm a bit perplexed I didn't identify the same pairings when I went through the method I linked to above.
Red
Black
Orange
White/orange
White/red
Yellow
Black/grey
Yellow/white
Red & white/yellow
solid and splits are the coils, so black and black/white are one coil...and so on for all four colours.
I'm not sure which two to pair for a and b, but i'll try to figure it out.
black - black/white
red - red/white
yellow - yellow/white
orange - orange/white
black - black/white
red - red/white
Hi Angel-tech,
Thanks for your earlier post. Just wondering if you'd had any luck identifying pairings?
I'd of thought this was a readily available piece of information, since presumably anyone upgrading an orac needs to go through this if they're using the original steppers? Can't find any mention of it though!
Thanks,
Luke
Thanks,
Luke
i have a similar motor here from a different machine and the wiring is,
black and white/orange
orange and white/black
yellow and white/red
red and white/yellow
which i assume is
A+
A-
B+
B-
which i assume is
A+
A-
B+
B-
