I have a Easiturn 3, I was using it the other week, when the power just tripped out.
I reset the power supply to the machine, and the auto toolchange unit came on, but the rest of the machine is dead.
I check all the fuses in the control, is there any other fuses in the base of the machine I've missed.
Thanks for any help.
Adee
There will be a PCB in the back of the machine. If you look look from the back there will be a inspection plate near the bottom in the centre. Inside you should be able to locate the fuses. I remeber some on the PCB but there may be some more also. It's a while since I looked at one of these.
I will have a look, but first I need to move it away from the wall.
