I have just acquired a second hand MicroRouter.
Thanks to this forum, I have found the quick start guide and the wiring diagram.
Is there a more comprehensive user guide available for the microrouter?
And if there isn't, can you please advise what sort of cutters I need please? (I should mostly be shaping MDF, hardwood, plywood and occasionally plastic).
Thanks in anticipation.
The used guide is accessable from the menu on the software CD.
If you dont have the CD you can download it from our site.
Attached is a link to Trends router cutter range.
These are a good product but dont buy the ones fitted with a bearing as they are for hand routing only.
https://www.trend-uk.com/en/UK/productgr ... tters.html
