2D Design Version 2 will not open certain files.
Hi i'm having probolems open up ceratin files that have been created by pupils on the the latest version of 2D deisgn but when i try and put them all together to collate them so they can be cut on the laser cutter i get this error message. They are all using 2d Design V2 2.09. I havent managed to see if io can pin it down to individual machines to see if thats the issue but at present it just seems to be random machines that for some reason causes problems.
The error message is:
"It appears that thisdata is form a latest version of the software and therfore cannot be loaded, please contact your supplier."
Thanks for your support
Simon
Re: 2D Design Version 2 will not open certain files.
I suggest you check the version of Techsoft on each indevidual workstation as I believe one of them will be running an older version.
Go to HELP ABOUT to check the version.
