Easiturn power chuck wanted
stevewatson
Post by stevewatson » Wed 23 Nov , 2011 12:28 pm
If anyone has an easiturn power chuck for sale please let me know. Cheers steve
SimonRafferty
Hardware/Software: Denford Cyclone P
EMCO PC Mill 100
Solidworks 2018
SimSolid
Re: Easiturn power chuck wanted
Post by SimonRafferty » Tue 13 Dec , 2011 16:01 pm
I have one! I've never used it - other than connecting it up to an air supply to see if it works (and it does).
It's in pretty good condition.
Make me an offer! (probably best by PM)
Si
stevewatson
Post by stevewatson » Wed 21 Dec , 2011 20:40 pm
Hi. Thanks for letting me know and sorry for the late reply. Does the chuck come with the correct gear to hook it up to an easiturn and what dia is the chuck.
Cheers Steve
SimonRafferty
EMCO PC Mill 100
Solidworks 2018
SimSolid
Post by SimonRafferty » Thu 22 Dec , 2011 9:19 am
The chuck has a pneumatic line to open/close the jaws. You will need to arrange your own pneumatic valves / air source. There is a spigot which sticks out of the bottom of the chuck to hold part of it stationary while the remainder rotates. You need to fabricate a fork to receive this as you slide the chuck in to place.
It has a D1-3 Camlock fitting so should attach directly to an easiturn.
I'll have to measure, but the chuck is between 200 and 250mm diameter.
Si
jpmiller
Hardware/Software: Denford easyturn pnc2
Converted to mach3
Denford triac servo /G simple/quickcam
Post by jpmiller » Fri 23 Dec , 2011 1:45 am
I have all of the other gear if you need it.
SimonRafferty
EMCO PC Mill 100
Solidworks 2018
SimSolid
Post by SimonRafferty » Thu 29 Dec , 2011 13:14 pm
The chuck is a Pratt Burnerd 1740-01710 6 1/2" diameter with 1 1/2" Bore. The overall diameter of the pneumatic manifold is 9".
It has two sets of soft jaws, one of which has been machined to grip circular section bar. The other has flat ends - ready to be machined. There are also two out of three hard jaws - not much use I know! I'm told they are a standard fitment though.
Si
