Quatromill/Fanuc 1008 Spindle Drive Fault
Posted: Wed 16 Nov , 2011 13:11 pm
I'm trying to diagnose a problem with our Quatromill, which was working last time we used it (several months ago). Essentially when we power it up, the Fanic OT-A displays a '1008 Spindle Drive Fault', which we can't clear under normal operation.
We've had a probe around the cabinet at the back, and the spindle drive unit is not powered, which would probably explain the error. The power seems to be applied via a relay, but this is never energised. There is power on the other side of the relay contact. If we manually operate the relay, the spindle drive unit powers and the error is removed from the screen.
We've checked all of the fuses and breakers that we can find, and also the voltages on the I/O card, which all seem correct. The only thing we have noticed is that diagnostic 0701 indicates that CRST is active, but the e-stop button is not pressed. Interestingly, diagnostic 0712 shows no flags at all, which does not make sense.
Is this likely to be a parameter setting that causes the drive relay not to be energised, or should we be looking for a hardware fault? Has anyone seen this kind of problem before? Does anyone have any wiring or further diagnostic information that they would be willing to share with us?
Any help or pointers will be gratefully received. Many thanks for reading!
Patrick
Patrick
