VR Milling 2.22 with Novamill
In the VR Milling screen (V2.22), with a Novamill connected and ON,...the "machine parameters" under 'set up' are greyed-out. Any ideas on how to solve/ make available?
Re: VR Milling 2.22 with Novamill
You need to disconnect from the machine.
You should update to the latest version of VRMilling which can be downloaded from the Denford website. Make sure you have the licence code\dongle first though.
OK, I will try this immediately. Thank You for the quick reply.
When he says disconnect from the machine, he means by pressing the machine link button in the software (ie don't disconnect the cable)
Machine parameters are not available in VR whilst the software is connected to the machine.
Yes Sir, I understand that. Thank You for having such a helpful forum. Cheers.
