coolant options
Post by Andycnc »
Has anyone fitted flood or mist coolant to a starmill?
If this was fitted as a factory option, was anything special done to the mill? eg, a drain hole cut in the base, some extra guards/seals to prevent moisture ingress anywhere?
25 years as Electronics design Engineer, cnc machines used for manufacture of prototypes. Have Boxford 240tcl and 260vmc, Denford starmill, used to have an Orac. All converted to run Mach3. Happy to try to help with any tech issues.
Hardware/Software: Windoze 10
Long shot on a ten year unanswered post, but has anyone any tips/advice on fitting coolant on a Starmill?
Hardware/Software: Starmill
Re: coolant options
Post by Manny »
Hi I am looking at doing this also, I see by the drawings it has an option for a mist relay, I don't pick my starmill up until Friday so will have a look at the electronics then :) Im looking at adding the fogbuster
Re: coolant options
Post by TDIPower »
have a loom on the novamill threads as various people have done it
Re: coolant options
Post by Steve »
Airmist does not require any modification to the machine. If set correctly there is hardly any residue left and it will evaporate away.
Martin, Steve, Mr Magoo
