anyone have the opto sensor board schematic GSM PC1607
for Orac Lathe
and how to set the correct pulse , i have a feeling either the sensors not aligned or the timing is out , so looking for general info
This might help:
viewtopic.php?f=43&t=3308
Have you searched all the Orac circuit diagrams - there may be more info in there
thanks found it !
If it's the same as the one on the starturn (which I think it is) you need to supply the sensor with a 12v supply and you will get a 5v output from the signal lines.
