SMCU Starmill Stepper Board Pinout? (Dir / Step and motor)
Hello All,
Does anyone know of any circuit pinouts for the SMUC Driver connections?
This is on an old starmill it has 3 X L297 based Parker Digiplan Drivers that connect to a mother board that has screw terminals for motor connection and an IDC connector for step dir.
If anyone could let me know the step/dir and motor connections that would be most helpful.
Kind Regards,
SRG
Re: SMCU Starmill Stepper Board Pinout? (Dir / Step and motor)
This might be relevant:
viewtopic.php?f=54&t=3272
Thanks for the link!
It has helped with regards to main motor out pinout but unfortunately it doesn't mention anything about the step/dir pinouts which I believe are delivered through the connector X11!?
It appears this is an older version than the mill I have as it only mentions the number keypad whereas the Starmill I possess has the front panel with the LCD, encoder wheel, buttons and emergency stop button attached to it.
Kind Regards,
SRG
Found the card Parker Digiplan sd2
Card info...
files/sd2_179.pdf
