Problem finding CNC files - DOS software/Tutor keyboad
Looking for some help please ref new (to me) Starturn CNC lathe. Using fanucmd software via tutor keyboard: menu system, jog, spindle, home, all working fine. I have set denford data command in autoexec to ref my cnc file directory. When loading a cnc file on the tutor I can see the directory and the file but when selecting a file, error "File not found" appears. Do files have to have a particular extension to be recognised, or what else is wrong here?
Re: Problem finding CNC files - DOS software/Tutor keyboad
Not sure if it's related but shouldn't you be using FanucLD ? (L for lathe as opposed to fanucMD - M for mill)
Thanks. Not sure if this will affect the problem I have, since jog and spindle work OK using this software, however using lathe rather than mill is the right thing to do!
I have 2 tutor keyboards: 1 fixed keyb; one with removable overlay..........am I right in thinking "LD" DOS software is for the overlay, and "L" for the earlier keyb???
I've never really seen a definative answer on the different versions...
these should help:
viewtopic.php?f=9&t=856&hilit=fanucld
viewtopic.php?f=9&t=294&hilit=fanucld
viewtopic.php?f=9&t=740
these should help:
