If it's DOS then it should work somehow. Even if you have to use dosbox or create a virtual dos installation (VMWare)
If it's the Apple or BBC versions, then 99.9% sure it won't (unless there are some very good emulators around??)
done it very simple actually. just run the fanucsld.exe file. works with windows xp no problem
