LaserCAM and QuickCAM 2D v1.12 released 11th Oct 2010
Post by Denford Admin » Mon 11 Oct , 2010 10:03 am
// 1.12 - Tooling data is re-read when starting the CAM wizard and when editing - incase tools have changed in VR Milling
// 1.12 - Material data is re-read when starting the CAM wizard and when editing - incase materials have changed in VR Milling
// 1.12 - When posting out, the TOOLDIAM (used in TOOLDEF) is now output correctly. This helps when the plan description isn't updated to reflect a new tool diameter being set (TOOLDEF Dxxx is the actual value that's been used by QC)
// 1.12 - Made some fixes when using it in Imperial / inch mode
// 1.12 - Added arc drawing by start, centre, end
// 1.12 - Fixed so that rectangles can be chamfered or filleted
As usual - check here for the latest version:
https://www.denford.co.uk/index.php?opti ... 5&Itemid=5
