VR Milling v5.34 released 25 May 2010
Check here to download the latest version of all software:
v5.34 - MRC40 added - CE type machine only
v5.34 - rapid feedrate is not set to the axes rapid if a 4th axis move is commanded - the Vertical Router would cause the 4th axis to run too quickly occasionally.
v5.34 - 64 bit and 32bit USB drivers updated - two new options on the CD starting menu
Re: VR Milling v5.34 released 25 May 2010
Did not see the update on the web site.
Best regards,
David Fhu
“Dream as if you'll live forever, live as if you'll die today.” - James Dean
It's currently still uploading (160 Mb) ....
With the new updated, for those user for older version VR Milling user, what should they do in order to upgrade their current software?
Do we need to uninstall and reinstall? Please advice.
Best regards,
David Fhu
It is uploaded now.
If they have version 2 VR Milling, then upgrade will be chargeable, and could require a hardware update to USB connection.
If they have an older version of V5 Milling, then it is best practice to UN install the current version first and then install the new version.
It is worth saving a copy of the offsets file before uninstalling / installing:
viewtopic.php?f=2&t=166
