- My Triac PC using Eurostep RS232 card (Red LED) and VR Milling 2.31 will occasionally do some random movement, usually after milling for some time. It gets bored
- Sometimes also, the spindle will just stop mid job - as though an M5 command had been issued. Restarting the program cures that - but in a long program this is very time consuming.
- I read elsewhere on the support BB, that a potential cure is to upgrade to a USB Eurostep card and VR Milling 5.2+ are these the only cures for these 2 problems?
- Is this an RS232 handshaking issue? If so, at which end is it most likely to be? If it is a the Black Box end, could I drive the RS 232 there via a USB (from computer) to RS232 (at black box)?
Any help on this gratefully appreciated
