hi there
does anyone know how to remove/limit the amount of backlash on the 'X' axis of my 'ORAC'
many thanks in anticipation
regards baz
You will need to adjust the Tab nut on the ballscrew.
If you remove the X axis covers & stepper motor you will see the Tab nut & washer behind the pulley on the Ballscrew. If you release the tab on the washer you should then be able to righen up the nut & reset the backlash.
hi martin
sorry for the delayed reply, i took to my bed ill soon after posting my problem.
many thanks for you assistance. everything is now sorted and backlash is no longer a problem. regards baz
