Mirac PC 1992 had a LCB3 control
Customer is looking for software to get his Mirac PC 1992 had a LCB3 control up and running.
Your Mirac PC 1992 had a LCB3 control which we cannot offer an upgrade for, it had a Baruffaldi RH80-6 Toolpost.
1. Create a DOS boot disc (I think this is what you type at the DOS prompt a:/format/s) you have to do this from DOS 6.22
2. From our web site select the old DOS software you require, sorry but I cannot be more specific, it could be Mirac.zip
and copy the files onto the boot disc
3. From our web site select the DRIVERS2 directory, https://website.denford.ltd.uk/support/9 ... s-software
4. I have copied a .OPT and .GO files from a later machine, I cannot be 100% sure they are right but it is a start. In your unzipped Mirac.zip machine software locate the Mirac.OPT file and the Mirac.GO files that are already on the boot disc and copy the information below into their respective directories. See the forum site for more information on the .OPT and .GO files. ( Note!! the last line of the .GO file below is flstep.app, this name usually relates to the software you are running, in this case FLSTEP, no doubt others on the forum can offer more advice)
.OPT
AUTOERROR 0
DRAGMARKING 0
DISPLAYSIZE 3
NARROWSIMBOX 0
utils_menu_1 Dos Access
utils_go_1 dos
utils_menu_2 Turning Designer
utils_go_2 ldesign
mirac_sdevice machine
SRAMDRIVE 3
SHOWTOOL 0
safespindle 150
slave_encoder 2000
SLAVE_SPINDLEF 0.85
SLAVE_SPINDLELAG 35
lowspindle 100
highspindle 5000
mint_mfact 200
CHUCKCENTREX 10
moverangex 85
machineextentx 100
moverangez 150
machineextentz 200
SLAVE_ACCEL 120
HIGHFEED 3000
HIGHFEEDZ 3000
SLAVE_XDATUMFEED 1500
SLAVE_ZDATUMFEED 1500
SLAVE_ATC 2
mintool 1
MAXTOOL 8
SLAVE_PCHUCK 1
NOAIR 0
slave_thread 1
inspect 1
datumorder 1
SLAVE_IO 1
.GO
IBM.RS2 1
$2F8 3 MACHINE
DENFORD1.KBD 1
18.2 $3F8 4
VGA.CRT 0
FLSTEP.APP
Just found these files as well
.OPT
AUTOERROR 0
DRAGMARKING 0
DISPLAYSIZE 3
NARROWSIMBOX 0
utils_go_1 dos
utils_go_2 ldesign
HIGHFEED 1200
SLAVE_XDATUMFEED 1200
SLAVE_ZDATUMFEED 1200
{SLAVE_SPINDLEFACTOR 1.2
mintool 1
maxtool 8
dc_brake 0
(TCTYPE 2
MACHINEEXTENTZ 156
MOVERANGEZ 156
SLAVE_BANK 1
.GO
IBM.RS2 2
$2E8 3 COM4
$2F8 3 MACHINE
DENFORD.KBD 1
18.2 $3E8 5
VGA.CRT 0
MIRAC.APP
Re: Mirac PC 1992 had a LCB3 control
I am going to try this out tonight and let you know if it works.
Hello Bradders
I tried your method but I can't get it right.
Should I put the UNZIPPED MIRAC Files into directory A:\Mirac
and also all the UNZIPPED Drivers2 Files into same directory again - A:\Mirac?
Thank you.
Don
You need to Unzip the files fiirst.
If you left mouse click on downloaded filed you should be able to select unzip then save them.
With it being a Mirac PC you don't need to create a dos boot disc so you could save the files anywhere & make a shortcut to the "Mirac.exe" file.
Martin wrote:You need to Unzip the files fiirst.
Thanks Martin.
Everything seems okay for now, will have to figure out how to use QWERTY to control MIRAC V2.25.
You might find my post here.
viewtopic.php?f=9&t=3837&p=14656#p14656
Not sure if you found this post:
viewtopic.php?f=15&t=2284
It is the manual which shows how to use the DOS software with a QWERTY keyboard instead of the Tutor.
