VR Milling v5.29 released 29th July 2009
Post by Denford Admin » Wed 29 Jul , 2009 13:33 pm
As usual, get the latest version from here:
v5.27-
Added low air press message to base (stLowAirPressure) a chance now to use comms(33) to show machine status or problems
Changes to force VR to show the datum symbol - otherwise it didn't update the datum position if the datum wasn't actually showing.
Changed machine not found dialog
Updated VMC 55xx (not 52xx) mints... mcode is now run in a task so it doesn't freeze all other tasks while for eg, waiting for an input
v5.28 -
Updates to make convert back to arcs more reliable (dxf import wizard)
Datum position (eg centre) not being updated unless you had the datum symbol showing - fixed (again)
Fixed VMC pro and std 4th axis mints which timed out on Mcodes (to do with mod to run mcodes in a seperate task)
v5.29 -
added a 2 sec delay after m3,m4,m13,m14 to allow spindles to ramp up to speed
fixes to coordinate transform window (eg mirrorX) because it didn't always draw properly
made spindle stop on all machines when M06 is executed. also, when it was stopped in certain machine mints, the control status still showed it as running.
Updated flash screen image
The file DisableFlashUpgrade.txt exists in the programs .exe directory then the Upgrade button is not shown - a request from a school when the kids were clicking upgrade then loosing the license and wasting lots of time.
Added version info to the main form caption (to help us when people send in screenshots)
Fixed a block restart bug where restart XYZ target positions were being parsed as 9e9
