How do i get my 4th axis to work ?
Post by bradders » Wed 22 Feb , 2006 15:04 pm
Post by bradders » Wed 22 Feb , 2006 15:05 pm
1. Make sure 8 way QM plug is connected
2. From the main menu bar in VR Milling select the SETUP option
3. From the dropdown box select the SETUP MACHINE PARAMETERS option
4. Password denny
5. In Machine Capabilities select 1V A,B,C (1,2,3) and change 0 to a 1
6. Come out of “Set up Machine Parameters” and a new window should appear CONTROL PANEL windows with A axis details
Use the . and / keys for jogging the 4th axis
Note !
While it is possible to connect the 4th axis without switching off the power to the machine it is inadvisable to do so as damage to the drive card could occur.
Post by Steve » Thu 02 Mar , 2006 17:46 pm
If you go to "help" "VR CNC Milling" in the welcome section there is information telling you how o configure the 4th axis! :)
