Romaxx CNC router
Romaxx CNC router
Customer writes - I am interested in software ( to generate G code) to run a Romaxx CNC router. (romaxx.com) I teach in a middle school, so the program would have to be simple enough for the students to use. Currently I am using PC Draft as my CAD program. I am sending you an attachment with a sample drawing DFX file to see if your software can read it. I also have the specs for the router if you need them, just let me know.
- test part.zip
- (858 Bytes) Downloaded 751 times
The DXF file can be opened by the Denford software:
VRMilling 5 and QuickCAM 2D or 3D.
Both these bits of software will be able to create G Code programs which may work on the romaxx.
QuickCAM 2D will give the benefit of being able to change to G Code output to suit different machines (via the post processor config file)
As VRMilling 5 will never be able to control to romaxx machine, I suggest that QuickCAM 2D and 3D will be the only options for you.
What we will need is an example gcode program consisting of lines and arcs, which runs OK in the romaxx CNC control software.
