Tool Turret Problems on Mirac
Posted: Tue 18 Apr , 2006 23:14 pm
Hi there.
I hope someone can give me some tips with this! I have a 1994 Mirac with the 8 Station Tool Turret which I bought from my old College when they stopped their engineering courses. A few weeks ago it developed a problem where it changes to the wrong tool (e.g. loads tool 6 instead of 7) but actually thinks it has the correct tool loaded. I adjusted the rotation sensor slightly which seemed to sort things out at the time.
However, over the last two weeks there has been a ticking noise whilst the turret is rotating and tonight it has started to load the wrong tools again! When I removed the aluminium cover over the rotation sensor it had coolant inside it despite the cover being well sealed down. Is there a seal from the front of the turret which may have failed?
I have a manual for the machine but in typical fashion I don't seem to have the page with the parts diagram or list for the turret.
Does anybody know anything about the following:
1. What may be causing the ticking noise?
2. Where might the coolant get into the housing about?
3. Is it normal for the rotation sensor to require regular adjustment or is this problem caused by turret wear/coolant ingress?
Sorry for the massive explanation!
Best Regards,
Gary
Best Regards,
Gary
