Microturn 2000 - Light does not work
Customer writes in ...
Microturn 2000 - light will not work with brand new bulb
Microturn 2000 - Light does not work - USA
The light unit is wired to the 24volt output of the transformer.
Check/Replace the 6.3amp fuse (F5) on the 24v output of the transformer.
Make sure the On/Off switch for the light unit is “On”. If the switch is bad, join the 2 blue wires going to the switch to bypass it.
Check voltage coming into the light unit.
Check the output voltage of the transformer in the light unit (small white wires).
Check the contacts to the bulb, clean and tight.
Some people have replaced the unit with an “Under the Cabinet” light fixture from the local home improvement store and wired it to the 110v side of the transformer.
