I would be most grateful if anyone can tell me the correct software to drive a STARTURN lathe. The manual tells you to install FANUCSLD, but then all subsequent screenshots in the manual are of MIRAC (!)
Neither are available on the Denford site.
Help very much appreciated.
I've put a few more DOS software disk images and PDF's on our main website. FanucSLD is there now.
Go to https://www.denford.co.uk/technical-support.asp
I'm hoping Mr Magoo
can do some sort of guide as to how you create a DOS disk for your particular machine.
I'm hoping Mr Magoo
Many thanks for uploading the STARTRURN fanucsld software. Unfortunately when I follow the user manual instructions (either copy all to c:\denford or run from a:\) I get :
'Error <128> Software aborted'
What a nuisance! any thoughts on what this means?
I am definitely running from the dos prompt - and have tried on a 486 sx25 and also a Pentium 75. These seem about the right genre for the Starturn.
A line comes up first saying something like 'denford starturn cnc software version X.XX, 1995'.
The next line is the error 128.
Thanks for your help and support.
I've been trying to test the FANUCSLD to reproduce your problem, but unfortunatly I do not have access to a win98 machine (and my laptop doesn't have a floppy drive!)
I think the problem may be a base memory issue - the software requires a minimum amount of free base ram (memory upto the 640k boundary).
Try formatting a floppy disk as a boot disk, then booting your PC from that, then running the FANUCSLD software. Alternatively, you could press f8 (I think) whilst your PC is booting from it's hard disk to bypass the Win98 startup files, then running the FANUCSLD software.
Appreciate the help, but my 2 PC's have Win 95 and win 3.11. As such they are surely typical of the age of the machine. The denford manual just says 'copy to hard disk' and they run. I have done exactly what a 1995 user would have done, and on the right type of machine too.
Running from a boot disk created the same error. Is this a DOS error code?
Am I the only man in universe with a STARTURN?!
I've just posted a topic that may answer your question.
Click here to view it.
It also occured to me that the software maybe displaying more info, but then clearing the screen before you have chance to see it. Piping the output of the program to a text file may give you more clues to the problem.
To do this, type the following at the command prompt...
FANUCSLD>output.txt
This will produce a file called OUTPUT.TXT that you can open with DOS EDIT or windows Notepad and may contain more than just the "128 software aborted" error
FANUCSLD>output.txt
