Micromill 2000 - Push Button Switch Bulb
Bulb is burned out on the Push Button On/Off Switch (Front Panel)
The replacement bulb is Radio Shack # 1819 Bayonet-Base Lamp; Rated voltage is 28v, Bulb Type is T-3-1/4,rated current is 40mA
Newer machines are fitted with an LED bulb so these should never fail!
