Mirac PC - help required with setting up
Posted: Fri 09 Nov , 2007 9:50 am
Hi all
I just acquired a MIRAC PC machine from a seller on Ebay - who assured me it was working etc etc.... however when I got back home with it I discovered there was actually very little available for me to actually set it up and run it to check it out.
What I received was the machine itself naturally - a FANUC keyboard and a few leads and a bunch of what I assume are in-line dongles. I also had a bunch of floppy disks which contained what I guessed was the software only to find they were basically all corrupted and couldn't be read or many of the files were corrupted. I tried them on a few of My PC's and only one machine could actually pull some of the content off the discs
I've popped here and done a bit of research and to be fair, I'm a bit confused as to what exactly is required to run this machine nowadays.
What I would like from one of the experienced users on this forum is basically to let me know exactly what I need to set this machine up and get it running. Things such as required leads - software etc..
I have an old PC that used to run Win 98 (yes really old) that I was intending to use to run the Mirac - but I'm unsure as to what connections and leads would be required for it..
I'm guessing I need the latest Lathe program and am I right in that this software no longer requires a dongle to run?
I have the one ribbon cable that I guess is for the fanuc keyboard and another cable that should be the connection then from the PC to the machine. However my old PC doesn't appear to have the right number of connectors for them as they seem to be similar to the large old Printer ports and most old PC's only had one of them and usually then another 2 smaller RS232 ports.
So please excuse my ignorance and let me know what i have to get hardware and software wise to set this machine up and get it running.
Many many thanks in advance
Here are some photographs of everything I had with the machine - some of the photos probably don't apply specifically to this request but I thought they may aid experienced users in better ID of the machine:
https://www.meshweaver.com/temp/Denford_ ... irac01.jpg
https://www.meshweaver.com/temp/Denford_ ... irac02.jpg
https://www.meshweaver.com/temp/Denford_ ... irac03.jpg
https://www.meshweaver.com/temp/Denford_ ... irac04.jpg
https://www.meshweaver.com/temp/Denford_ ... irac05.jpg
https://www.meshweaver.com/temp/Denford_ ... irac06.jpg
https://www.meshweaver.com/temp/Denford_ ... irac07.jpg
https://www.meshweaver.com/temp/Denford_ ... irac08.jpg
https://www.meshweaver.com/temp/Denford_ ... irac09.jpg
https://www.meshweaver.com/temp/Denford_ ... irac10.jpg
https://www.meshweaver.com/temp/Denford_ ... irac11.jpg
https://www.meshweaver.com/temp/Denford_ ... irac12.jpg
https://www.meshweaver.com/temp/Denford_ ... irac13.jpg
