Description of problem:
When the students create a program on the cam designer, they make a g-code, the transfer to the VR turning program is incorrect. The radiuses are backwards. I have to change the radius from g3 to g2 and vise-versa. If I don’t the cutter will gouge the billet. Sometimes when the VR turning 3D shows it runs correctly when the machine runs, it still gouges the Billet.
    				    					Resolution:  Please see the links below.  It does not appear that you have a malfunctioning machine or defective software, but rather may just need to either make a few adjustments in your program or re-set your offsets.   The G codes are set up for industry where the cutter is on the back side of the material.  The G codes need to be manually changed or follow the instructions in tech article #3005 on changing the internal code for the Microturn so that the G Codes will be correct when machining a part that is designed in Lathecam.
https://www.denfordata.com/downloads/usa ... s/3005.pdf
This way you will not have to manually change the G Codes. However in 2D/3D simulation it will be wrong, as the tool is coming in from the back side of the material.
Search for the fanucl.ini file and found in C:\Denford\Config.
Open the fanucl.ini file in Notepad and scroll down until you find CNC Lathe (inches) and add the lines
CWCode=3
CCWCode=2
Then scroll down farther until you find Microturn (inches) and add the lines
CWCode=3
CCWCode=2
If you are working in Metric, do the (metric) machines also.
Make sure you SAVE (Ctrl + S) before closing the file.
Other links you may find helpful:
viewtopic.php?t=754
viewtopic.php?t=676&highlight=lathecam
Lathecam Designer Manuals:
viewtopic.php?t=1122&highlight=lathecam
viewtopic.php?t=73
CWCode=3
CCWCode=2
CWCode=3
CCWCode=2
viewtopic.php?t=754
viewtopic.php?t=73
