FEEDRATES VMC1300
All info relating to the Denford VMC1300 and VMC1300 Pro CNC milling machines
FEEDRATES VMC1300
Post by Martin » Thu 06 Sep , 2007 12:54 pm
PLEASE TELL ME THE RECOMENDED FEEDRATE FOR MILD STEEL THERE DOES NOT APPEAR TO BE ANY INFORMATION ON YOUR WEBPAGE!
Post by Steve » Thu 06 Sep , 2007 13:35 pm
The settings in the material library of VR milling suggest 75mm/Min at 2500RPM with a cut depth 25% of tool diameter. Typically for a 6mm cutter.
Depending on the size of the cutter this will be about right.
The cutter type diameter and number of flutes will also require changes but start at these values and see how it cuts.
For larger diameter cutters reduce the spindle speed and for smaller ones increase it.
Post by Martin » Thu 06 Sep , 2007 14:13 pm
THANKS FOR THE INFO -
PLEASE TELL ME THE RECOMENDED 'SURFACE SPEED' SO THAT I CAN CALCULATE ANY DIAMETER.
CUTTING MILD STEEL WITH A HSS CUTTER
THANKS
Post by Steve » Fri 07 Sep , 2007 16:27 pm
6mm dia is aprox 20mm circ speed is 2500RPM so surface speed of the tool is 20 x 2500 = 50000mm/min
Feed is 75mm/min so cut per rev is 666 Revs / mm cutting or
cut of 0.0015mm / Rev
Diverse
Hardware/Software: Dell pc running VR CNC milling 5, QuickCAM 2D Design and QuickCAM PRO
Re: FEEDRATES VMC1300
Post by Diverse » Tue 06 Jul , 2021 15:46 pm
Hi. I’m new to this form so hope I’m directing this question in the right place. Has anyone had experience tapping m2 and m3 threads in brass and aluminium using the vmc 1300? I appreciate I’ll need a tapping head but just wondering in the success rate of tapping holes this size. Thanks.
