I am using Ver. 1.6.5.328 and am having the following problems:
When drawing the X & Y Coordinate values do not coorrespond with the correct units chosen. I choose "Inch" and the coordinates display metric ( I think) but they are high numbers, not what is expected.
also, when using the CAM Generate option, the Z axis depth of cut set doesn't not output correctly in the post file. Each time I try to post out a design, the Z setting is 3 times larger. This makes for a pretty good tool crash if not expecting it.
any help?
albert rossner
Jackson Area Career Center
Jackson, MI USA
517-740-4973
albert.rossner@jcisd.org
albertrossner@netzero.net
Can you try and download the latest version and update your installation?
https://www.denfordata.com/downloads/qui ... gn_1_7.zip
I can see the problem when in inches that as you draw the coordinates at the bottom of the screen are displayed in mm even though inches are selected.
I will pass to the software department for a fix.
Keep your eye on downloads as it will change as soon as the fix is done.
