LaserCAM and QuickCAM 2D v1.6 released 19th June 2007
Notes on v1.6:
added Quickcam version info into the post output as a comment
more fonts added to the install
fixed the problem where clicking on the select arrow again, would stop you from doing a rectangle select (froze up the select in the cad window)
fixed problems where arcs/circles/rectangles would revert back to original orrientation if grouped, then mirrored
added make/break group to the popup menu
added Plunge Feed Percentage=25 into post processor file to speed up plunging in some machines/materials
fixed open-with file (double clicking an mcm file) which had stopped working
put minimum widths on the toolbars (you could make zero width when floated)
