Triac homing problem
Re: Triac homing problem
Post by Martin » Thu 08 Mar , 2012 21:31 pm
Martin wrote:Hi Ray,
Where is this machine located?
Is it Selby College?
If it is the Selby machine then you will need a special mnt & mex file that I compiled with Andy's help when it was upgraded. If you unzip the files & then copy them over the original in the VRMilling directory.
rbarnes
Hardware/Software: triac pc with v5 milling
Post by rbarnes » Tue 13 Mar , 2012 19:54 pm
Hi, The machine is at the Isle of Man College. The switches operate with a metal plate over them, but not when the axis is driven over them. Checking out your links next Thanks.
Post by Denford Admin » Wed 14 Mar , 2012 12:11 pm
You could always try adjusting the switches to be closer to the bit they are supposed to be seeing
PS - forget to put a link to the balluf switches in my previous post, here it is:
viewtopic.php?t=2621
