The above has failed. Only details I can see is the manufacturer Lambda, now TDK-Lambda I think. It is clearly just a 200v/24v switching power supply, but should I be looking for anything in particular amp wise. According to the wiring diagram it only supplies the ESR circuit.
In the meantime, any reason not to temporarily use an adjustable bench power supply?
Thanks.
