Hi all
Hoping you can help with a very simple question
I am thinking of buying a Denford Starmill with mach 3 to use for milling brass, aluminum and stainless steel parts for an orrery / clock parts etc
initially using 3mm thick CZ120 brass - will the starmill handle this ok do you think ?
Many thanks
Ian
Hi Ian
I don't have a Starmill but am sure it will cut the parts for clockmaking, especially brass components but like any machine you will need sharp cutters on that material for a pristine finish on a skeleton clock !!!!
Aluminium should not present any problems.
Stainless steel is available in several grades, some are really tough to cut and best avoided, a Starmill should cope with the easier to cut grades provided you keep the tool cutting and not rubbing, some form of coolant may be required.
Hope this helps.
Rgds, Emgee
Hope this helps.
Rgds, Emgee
