depth of cut issues
ccamfield.ch6
Hardware/Software: denford mrc 40 and 2 d design
depth of cut issues
Post by ccamfield.ch6 » Wed 22 Jan , 2014 13:10 pm
I have a mrc 40 / compact 1000.
I am a dt technician and our IT technician has produced a program to cut out some shapes.
I have the machine set to metric. The board we use is 6mm thick
IT guy says he has asked it to cut 1.5mm each time over a thickness of 6mm. so 1.5 3.0 4.5 6.0 pass until it is all cut out.
What the machine is actually doing is 1.5 2.0 3.0 2.0 4.5 2.0 6.0. so not always cutting just moving around.
is this something anyone else has encountered? machine error ? human error?
any help would be great as it would certain speed it up a bit
Re: depth of cut issues
Post by Martin » Wed 22 Jan , 2014 16:48 pm
What software are you using to create the machine file?
If it's a 2D file then you just need to set the step down percentage to suit the tool. if it is a 6mm cutter then a 25% would be 1.5mmm per pass.
ccamfield.ch6
Post by ccamfield.ch6 » Wed 22 Jan , 2014 16:52 pm
I'll forward this to our IT guy. Im yet to have the training course but booked in !
ccamfield.ch6
Post by ccamfield.ch6 » Thu 23 Jan , 2014 8:53 am
Reply from our IT guy
Hi Chris,
I used the Denford VR Milling V5 software from a 2D DXF file. The initial cuts were at 1mm per pass, it just seems to repeat sections or add in extra steps not initially programmed.
IE 6 steps starting at 1mm – 6mm (depth of MDF) but its doing something more like 12 passes but in a random order.
My last test was doing something like this pattern
Pass1 – 1mm
Pass2 – 2mm
Pass3 - 1mm
Pass4 – 3mm
Pass5 – 2.5mm
And so on with seemingly no pattern.
Post by Martin » Fri 24 Jan , 2014 8:16 am
Can you post the dxf file & the G & M code program?
ccamfield.ch6
Post by ccamfield.ch6 » Fri 24 Jan , 2014 13:28 pm
hope ive attached them ok
Rodni_Board1.dxf
(247.99 KiB) Downloaded 943 times
Rodni_Board1V2.fnc
(134.75 KiB) Downloaded 1033 times
