Hi there, can anyone help.
I have an Orac lathe and the X axis has just stopped working. I can hear the servos fire up when I release the emergency stop button. Both motors are holding their positions, the Z axis jogs fine but the X axis servo will switch off and de-energise the motor as soon as I touch either of the X axis jog buttons. It also fails in Program mode.
Any suggestions greatly appreciated
Rip it open and swop the stepper drives over if its the drive, the other axis will now have the fault.
probably your typo, but they're not servos on the orac (unless mr denford made a special one) they're stepper motors, quite different
www.la-coterie.com
www.la-coterie.com
Oops thought they were servo motors, I'm a bit of a bonehead when it comes to the workings of these machines.Triac whizz wrote:
Anyway thanks for the replies.
Regarding the X axis I can see that both green LEDs on the cards are illuminated when the Stop Button is released, when either of the X axis jog buttons are depressed the Green LED on the X axis card goes out and the Red LED immediatley below it illumunates.
Just about to swop the cards over.
Hi Davedavidimurray wrote:Have you looked at the manual in the downloads section - there should be one in there for the CD20 which gives some information on the LEDs and what they mean.
Dave
Yes according to the 'troubleshooting' guide the first red LED suggests an 'Overload' - short circuit in the motor. However I have swapped the cards over and the motor works fine. So could the card be at fault?
