Denford Industrial Text Editor for DOS CNC machines
Posted: Thu 22 Jun , 2006 13:37 pm
Here is the DOS industrial text editor to run on DOS based machines.
It will help with the loading and saving of programs to your older Denford Machines.
https://www.denfordata.com/downloads/dos ... editor.zip
(Thanks to MrMagoo for this file)
It will solve all the problems people are having, trying to talk to the old PNC3 Triac machines (no need for two cables, supports all the PNC3 handshaking).
:wink:
how to setup up text editor
Posted: Wed 05 Jul , 2006 23:04 pm
by -=PAB=-
how and what settings must i use for my triac atc 1990??
Posted: Thu 06 Jul , 2006 9:37 am
This topic mentions some settings: (don't know if its correct or not)
https://denfordata.com/bb/viewtopic.php?t=114
Posted: Thu 06 Jul , 2006 22:24 pm
by Mr Magoo
Also this for the Editor s/ware...
select "Install Comms", then "Load Settings", delete the current entry of EDITOR.CS, press return and you will be presented with a list of available files - For example, choose PNC.CS for a Triac PNC3 controller. Do the same from the "Configure" menu option
Other Settings...
FANUC.CS - any Fanuc 0M/0T controller
IHEID.CS - Heidenhain TNC355 (and similiar) in ISO mode
DHEID.CS - Heidenhain TNC355 (and similiar) in DIALOG mode
TRIAC.CS - Not sure :?: Could be Triac PNC3, Could be Triac Faunc :!:
You can save your prefered settings file as EDITOR.CS (overwriting the original EDITOR.CS) if you want them to load at start-up. (In the ZIP file, EDITOR.CS is a copy of FANUC.CS)
And of course same goes for the CFG file too
Posted: Thu 23 Apr , 2009 8:51 am
Bradders has uploaded the manual for the Industrial Text editor here:
viewtopic.php?t=2056
Re: Denford Industrial Text Editor for DOS CNC machines
Posted: Thu 30 Jan , 2014 21:33 pm
by hexkey
hello,
Im in process of wearing out a 1987 triac pnc3. I do not have any tapes, so I'm looking to use Industrial Text Editor and an older Pc with XP. Ive only loaded up IndusTextEd on the PC and have managed to save programs and reload to the PC only. I have completed a 9 pin (pc's COM 1) to 7 pin cable and will commence with loading to the triac soon. My question is: How do I, or Do I need to use the ACK or STX stuff. On this forum sometimes its mentioned and other times not. But If I do need that, It doesnt seem to work using Ctrl+B or Ctrl+f. Does anyone know to help. Any informatoion would be helpful. Hexkey
