Error message “Emergency Stop Button Pressed”
Posted: Wed 22 Feb , 2006 15:11 pm
by bradders
Causes of the Error message “Emergency Stop Button Pressed”
Posted: Wed 22 Feb , 2006 15:12 pm
by bradders
1. Is the E Stop button out ?
2. Are any of the axes on limit switches? Press axis override button in and hold and jog axes off switches
3. If an ATC is fitted pressure switch is in the E Stop circuit
Q. The "Emergency stop button pressed" error message may be because one on the axes is physically on a over travel limit switch which are in series in the emergency stop circuit.
A. With the machine and VR Milling software running, press and HOLD IN the AXIS OVER TRAVEL BUTTON, then select the HOME ALL button in the VR Milling software CONTROL PANEL and the axes should home, if successful the JOG and AUTO tabs should become visible next to the HOME tab in the VR Milling software CONTROL PANEL
Posted: Tue 07 Mar , 2006 11:24 am
by bradders
There are 2 contacts on the Emergency Stop button
Contact 1 - 0V (GND) from Denstep board to Input 6 (Pin 9) Denstep
board. (Software monitors the status of the input)
Contact 2 - 24V via GIR (Guard Interlock Relay) to the Guard solenoid
Posted: Mon 02 Oct , 2006 10:23 am
by bradders
Microrouter / Microrouter Compact
When the Emergency Stop button is pressed it stops 24v going to the Emergency Stop Relay (ESR). This opens all the ESR’s contacts and hence stops GND (TB1 “Datums and Limits” terminal 2) going to the STOP (TB1 “Datums and Limits” terminal 6) and hence we get the “E Stop Button Activated” Message on the screen
Check fuses F2 and F3 as these are 240v to the transformer and 24v to E Stop button
Microrouter
This usually has a second contact on the E Stop button, and this supplies 24v via the Guard Interlock Relay (GIR) to the Guard solenoid
